Tries to find an enabled button by its title, and click it.
Section titled “Parameters”Target app
Section titled “Target app”Selecting "frontmost app" will try to find the button in the app currently in the foreground (default).
Select a specific app will try to find it in that one app.
Type: An app from a pre-defined list of available apps
Button title
Section titled “Button title”The title (or partial title) of the button that should be clicked.
Title selection
Section titled “Title selection”Select whether to look up the button by title or partial title.
- title
- partial title
Pause after clicking
Section titled “Pause after clicking”This adds a short pause after clicking the button.
- no pause
- 0.2 secs
- 0.5 secs
- 1.0 secs
- 1.5 secs
- 2.0 secs
- 3.0 secs
- 4.0 secs
If button can't be found
Section titled “If button can't be found”If the specified button couldn't be found, the action can either cancel the workflow and raise an error, or it could silently and gracefully just return nothing. This might be preferable if you don't want the workflow to stop while being able to check for its return value in an If block down the line.
On success, it returns a YES value.
- stop and raise error
- return no value
Section titled “Return Value”Boolean (YES/NO)
Section titled “Related Links”- Search the UI Actions community forum for "Click Button"
