UI Actions icon Home UI Actions 0.9.2 › Actions
UI Actions › Actions › Move/Resize Window
Moves and/or resizes a window.
Please note: Windows may have an fixed max and/or min size, so resizing them might not always work as expected. They will also never exceed the screen bounds.
The window to be configured.
Type: Window reference
Should the window be moved, resized, or both?
  • Move window
  • Resize window
  • Move and resize window
Specify if the entered values are percent or pixels.
  • percent
  • pixels
The desired horizontal position of the window's upper left corner, in the selected unit, measured from the upper left corner of the current screen. Optional.
Type: Number
The desired vertical position of the window's upper left corner, in the selected unit, measured from the upper left corner of the current screen. Optional.
Type: Number
The desired width of the window, in the selected unit. Optional.
Type: Number
The desired height of the window, in the selected unit. Optional.
Type: Number
Window reference
