Appends text to a note, either to the very end of the note (default) or to the section below a particular headline in a note.
Section titled “Note Lookup”Specify which note should be looked up or manipulated by the action:
- "note": If you want to use another AFO action’s Note result, pick this option.
- "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
- note
- note with UID
Section titled “File Path”The path of the note, relative to the vault root.
Section titled “Obsidian Note”A Note that was returned by another AFO action.
The text to append to the note.
Headline
Section titled “Headline”The headline must be entered exactly as it appears in the note: headline levels, capitalization, punctuation etc. For example, ## My Headline, ### My Headline, and ## my headline are not identical.
Only applicable when "Append below headline" mode is enabled.
Placement
Section titled “Placement”Where to append the text.
- end of the note
- end of the section below the headline
Ensure newline
Section titled “Ensure newline”If enabled, a line break will be added to the inserted text if it does not already have one. Useful if you have a piece of text that does not have a line break at the end, but should.
If headline is missing
Section titled “If headline is missing”When adding text below a headline, and the requested headline is missing, what should happen?
Only available when Placement is set to "end of the section below the headline".
- Show error
- Add headline
- Do nothing
Create note if necessary
Section titled “Create note if necessary”If the note couldn't be found and this option is enabled, a new note will be created so text can be appended; if the option is disabled, the action will return an error.
Section titled “Open or focus note”If enabled, after a successful operation, the note will be brought to the front in Obsidian.
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Append Note"
