Queries Obsidian for the existence of a specific note. Returns YES or NO.
Section titled “Note Lookup”Specify which note should be looked up or manipulated by the action:
- "note": If you want to use another AFO action’s Note result, pick this option.
- "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
- note
- note with UID
Section titled “File Path”The path of the note, relative to the vault root.
Section titled “Obsidian Note”A Note that was returned by another AFO action.
Section titled “Open or focus note”If enabled, the note will be brought to the front in Obsidian if it exists.
Section titled “Return Value”Boolean (YES/NO)
Examples
Section titled “Examples”If you want to test whether a note Hello there.md exists, you'd set this action's "File Path" parameter to Hello there. This would be followed by a built-in "If" action that checks the result of the "Check For Existence…" block using an is comparison – a positive result means "note exists", a negative "note doesn't exist":
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Check For Note"
