Actions for Obsidian › Actions › Clear Note Properties
Removes the entirety of a note's properties (and therefore, its frontmatter).
Specify which note should be looked up or manipulated by the action:
  • "note": If you want to use another AFO action’s Note result, pick this option.
  • "note at file path": The full path of the note, should be used if you already know the full file path (including folder and file extension).
  • "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
  • the current Periodic Note (daily, weekly, etc.)
  • note
  • note at file path
  • note with UID
The path of the note, relative to the vault root.
A Note that was returned by another AFO action.
Note reference
