Creates a Periodic Note for the current date.
The note can be created empty, or you can pass a note body. It's also possible to apply a template (either using the community plugin Templater or the core plugin Templates). Passing a note body and applying a template are mutually exclusive.
Periodic Note Lookup
Note Body
The text body of your new note.
The use of this parameter depends on your After creating the note … selection. Passing a note body or applying a specific template will cause Obsidian to ignore any template you may have set for its Daily Note core plugin or Periodic Notes community plugin, so if you want to see your usual template applied, leave Note Body empty.
Template Path
The full path of a Templates or Templater template, relative from the vault root.
What should be done after the file has been created?
- insert note body
- apply Templates (core plugin)
- apply Templater
Strategy for dealing with an existing note
If there is already a current Daily Note, the default behavior of the action is to skip the attempt to create the note and leave it as it is. You can also choose to overwrite the note (i.e., trash it and create a new one from scratch) or to abort with an error.
- Show error
- Overwrite
- Leave note as-is
Type: Boolean (YES
/NO
- Search the Actions for Obsidian community forum for "Create Periodic Note"
