Creates a note.
The note can be created empty, or you can pass a note body. It's also possible to apply a template (either using the community plugin Templater or the core plugin Templates). Passing a note body and applying a template are mutually exclusive. Passing a note body or applying a specific template will cause Obsidian to ignore any existing "Folder Templates" rules in Templater that may have been set for that folder.
The default behavior in case there's already a note with the same name / at the requested file path, the base file name will be suffixed with a number. You can also choose to overwrite the note or skip the creation of a new, suffixed note (i.e., leaving it as it is).
Section titled “Note Lookup”Specify which note should be created by the action:
Section titled “File Path”The path of the note, relative to the vault root. It may contain folders; these folders will be created if necessary. For instance, my/new/notes/Hello will create the note Hello.md in my/new/notes/. If the folder structure my/new/notes/ didn't exist, it will exist when the action is finished.
The action will append .md to the note filename if necessary, as mentioned in the example above.
Note Body
Section titled “Note Body”The text body of your new note.
Passing a note body will cause Obsidian to ignore any template you may have set for its Daily Note core plugin or Periodic Notes community plugin, so if you want to see your usual template applied, leave this parameter empty.
Only available when After creating the note … is set to "insert note body".
Template Path
Section titled “Template Path”The full path of a Templates or Templater template, relative from the vault root.
Applying a specific template will cause Obsidian to ignore any template you may have set for its Daily Note core plugin or Periodic Notes community plugin, so if you want to see your usual template applied, leave this parameter empty.
Only available when After creating the note … is set to "apply Templates (core plugin)" or "apply Templater".
Section titled “After creating the note …”What should be done after the file has been created?
- insert note body
- apply Templates (core plugin)
- apply Templater
If note already exists
Section titled “If note already exists”In case there's already a note with the same name / at the requested file path, the default behavior is to suffix the base file name with a number. You can also choose to overwrite the note or skip the creation of a new, suffixed note (i.e., leaving it as it is).
- Create note with suffix
- Overwrite
- Leave note as-is
If periodic note already exists
Section titled “If periodic note already exists”In case there's already a current periodic note of the type, the default behavior of the action is to skip the attempt to create the note, and leave it as it is. You can also choose to overwrite the note (i.e., trash it and create a new one from scratch) or to have the action return an error.
- Show error
- Overwrite
- Leave note as-is
Section titled “Open or focus note”If enabled, after a successful operation, the note will be brought to the front in Obsidian.
Section titled “Return Value”Related Links
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Create Note"
