Trashes or deletes a note. By default the note will be moved to the trash (as configured in Obsidian under Settings → Files & Links → Deleted Files).
The action will throw an error if the specified note doesn't exist, so it's best to use it after the "Check For Existence Of Note" action has determined that it does exist.
Section titled “Note Lookup”Specify which note should be looked up or manipulated by the action:
- "note": If you want to use another AFO action’s Note result, pick this option.
- "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
- note
- note with UID
Section titled “File Path”The path of the note, relative to the vault root.
Section titled “Obsidian Note”A Note that was returned by another AFO action.
Delete immediately and irrevocably
Section titled “Delete immediately and irrevocably”When enabled, the note is deleted immediately, bypassing the trash folder.
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Delete Note"
