Returns the most recent Daily, Weekly, Monthly, Quarterly or Yearly Note.
If there is a current note (e.g., for today, for this week, etc.), it will be considered the most recent, otherwise the most recent past note will be returned.
The note is returned as Note, which gives you access to the entire contents of the note, as well as separate fields for its body, its front matter, and its file path.
The action will return an error if there is no note at all.
Periodic Note Type
Type: Boolean (YES
/NO
- Search the Actions for Obsidian community forum for "Get Most Recent Periodic Note"
