Actions for Obsidian › Actions › Get Note Properties
Returns a dictionary containing a note's properties.
If the note's frontmatter contains a structure that Obsidian can't process, the note properties will be empty, because that's what Obsidian will return in that case.
Specify which note should be looked up or manipulated by the action:
  • "note": If you want to use another AFO action’s Note result, pick this option.
  • "note at file path": The full path of the note, should be used if you already know the full file path (including folder and file extension).
  • "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
  • the current Periodic Note (daily, weekly, etc.)
  • note
  • note at file path
  • note with UID
The path of the note, relative to the vault root.
A Note that was returned by another AFO action.
Dictionary
My note "Hello.md" contains the following front matter:
createdAt: 2023-11-06
list:
- one
- "2"
- three
Since this action returns a dictionary, I can access the single keys using a Get Dictionary Value action:
The 'Get Note Properties' action accessing the 'Hello' note in my vault 'Workbench', followed by a 'Get Dictionary Value' action using the prior action's result, accessing the value of the `createdAt` key, which returns string '2023-11-06
Accessing the "list" key, I get its value, which is a list of strings:
The 'Get Note Properties' action accessing the 'Hello' note in my vault 'Workbench', followed by a 'Get Dictionary Value' action using the prior action's result, accessing the value of the `list` key, which returns its list string, i.e. 'one', '2', and 'three
