Searches for a specified placeholder and either adds text above, below, or replaces it entirely.
Section titled “Note Lookup”Specify which note should be looked up or manipulated by the action:
- "note": If you want to use another AFO action’s Note result, pick this option.
- "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
- note
- note with UID
Section titled “File Path”The path of the note, relative to the vault root.
Section titled “Obsidian Note”A Note that was returned by another AFO action.
Placeholder
Section titled “Placeholder”A "placeholder" is a one-line comment in a Markdown note: a piece of text enclosed in double percent signs, e.g. %%My Placeholder%%. Since Obsidian does not render the comment outside of edit mode, it is perfect for marking places in a document where text can be added later.
Use the %%placeholder%% style in the body of the note, and the #placeholder# style in the frontmatter (which is YAML and not compatible with Markdown's percent style).
If the placeholder parameter doesn't contain any delimiters (i.e., if the double percent or the hash sign is missing), the action will enclose the placeholder in double percent signs. However, it is recommended not to omit them.
Replacement
Section titled “Replacement”The replacement text, i.e. the piece of text you want in your note instead of the placeholder.
Allow empty replacement
Section titled “Allow empty replacement”When enabled, your replacement can be blank, which would effectively just remove the placeholder from the note.
Where should the text be inserted?
Section titled “Where should the text be inserted?”The text can be placed above the placeholder, below it or it can replace the placeholder entirely.
Hint: When adding items to a list, and you want to add new items to the end of the list, select "above placeholder"; if new items are supposed to go to the top of the list, select "below placeholder".
- above placeholder
- below placeholder
- replace placeholder
Section titled “Open or focus note”If enabled, after a successful operation, the note will be brought to the front in Obsidian.
Examples
Section titled “Examples”Suppose you have a note Placeholder demo.md with the following content and a placeholder %%placeholder1%%. We'll insert the texts text 1, text 2, and text 3 in sequence.
## Headline 1
%%placeholder1%%
## Headline 2
something elseInserting above the placeholder
Section titled “Inserting above the placeholder”The result would be:
## Headline 1
text 1text 2text 3%%placeholder1%%
## Headline 2
something elseInserting below the placeholder
Section titled “Inserting below the placeholder”The result would be:
## Headline 1
%%placeholder1%%text 3text 2text 1
## Headline 2
something elseThis is because after text 1 is inserted, text 2 is placed directly below the placeholder (as it should be), i.e. in-between the placeholder and text 1 .
Replacing the placeholder
Section titled “Replacing the placeholder”The result this time:
## Headline 1
text 1
## Headline 2
something elseThe first insertion replaced the placeholder, and text 2 and text 3 have nowhere to go.
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Insert Text At Placeholder In Note"
