Brings the Obsidian app to the front and opens the specified note.
This action will throw an error if the specified note doesn't exist, so it's best to use it after the "Check For Existence Of Note" action has determined that it does exist.
Section titled “Note Lookup”Specify which note should be looked up or manipulated by the action:
- "note": If you want to use another AFO action’s Note result, pick this option.
- "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
- note
- note with UID
- current Daily Note
- current Weekly Note
- current Monthly Note
- current Quarterly Note
- current Yearly Note
- most recent Daily Note
- most recent Weekly Note
- most recent Monthly Note
- most recent Quarterly Note
- most recent Yearly Note
Section titled “File Path”The path of the note, relative to the vault root.
Section titled “Obsidian Note”A Note that was returned by another AFO action.
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Open Note In Obsidian"
