Selectively removes one or more keys from a note's properties.
Section titled “Note Lookup”Specify which note should be looked up or manipulated by the action:
- "note": If you want to use another AFO action’s Note result, pick this option.
- "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
- note
- note with UID
Section titled “File Path”The path of the note, relative to the vault root.
Section titled “Obsidian Note”A Note that was returned by another AFO action.
Property key
Section titled “Property key”Enter a single property key or pass in the result of any List-type action.
Type: Text (list)
Section titled “Open or focus note”If enabled, after a successful operation, the note will be brought to the front in Obsidian.
Section titled “Return Value”Examples
Section titled “Examples”Let's say I want to remove the property keys "tags" and "modifiedAt" from the note "Hello.md" in my vault "Workbench", then I have two options: I can pass in a list …
… or I can specify the keys one by one, like so:
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Remove Keys From Note Properties"
