Renames or moves a note.
This action will throw an error if the specified note doesn't exist, so it's best to use it after the "Check For Existence Of Note" action has determined that it does exist.
Section titled “Note Lookup”Specify which note should be looked up or manipulated by the action:
- "note": If you want to use another AFO action’s Note result, pick this option.
- "note with UID": Use this if you are using unique identifiers for your notes, and you prefer to look them up by the UID.
- note
- note with UID
Current File Path
Section titled “Current File Path”The path of the note, relative to the vault root.
Section titled “Obsidian Note”A Note that was returned by another AFO action.
New File Path or Name
Section titled “New File Path or Name”If the new file path contains a folder structure, that folder structure must exist, i.e. it won't be created automatically.
If the new file path is the same as the original one, nothing happens.
If the new file path already exists, an error is returned. If the new file path specifies a destination folder that does not exist, an error is returned.
Please note that to move the note to a new folder, you'll need to specify the full destination path, i.e. folder and file name.
Examples
Section titled “Examples”Current file path Note, new file path Great Note:
Note Note.md is renamed to Great Note.md.
Current file path Note, new file path /Great/Note:
- If the folder
/Great/exists:Note.mdis moved from its place at the root level of the vault into the folder/Great/. - If the folder
/Great/does not exist: An error.
Section titled “Related Links”- Search the Actions for Obsidian community forum for "Rename/Move Note"
