Searches for a string or regex pattern in the current Daily, Weekly, Monthly, Quarterly or Yearly Note and replaces it.
This action will throw an error if there isn't a Periodic Note for the current date, so it's best to use it after the "Check For Existence Of Periodic Note" action has determined that there is one.
Periodic Note Lookup
Search term
Either a fixed string or a regular expression, depending on the setting "Search term is a regular expression".
Regular expressions must be valid Javascript regex, see MDN or RegExr.com (unaffiliated) for info.
Replacement
By default, the search term is searched for as-is. With this option enabled, the search term is treated as a regular expression instead, and must follow the format /search term/
(trailing flags (g
, s
, i
, etc.) are allowed).
Type: Boolean (YES
/NO
Type: Boolean (YES
/NO
- Search the Actions for Obsidian community forum for "Search And Replace In Periodic Note"
